Can xnview generate thumbnails from mpeg 2 files?
ph0b0s321
Thanks for creating this brilliant program. I use it both on my desktop and pocketpc. I wanted to confirm though, if Xnview supports making thumbnails of mpeg2 and realmedia files?
Mpeg2 was mentioned as being supported else where in this forum, but I cannot get Xnview to thumbnail any of my mpeg2 files. I normally use powerdvd 7 as my mpeg2 directshow filter for windows media player. But just to make sure I deinstalled and unregistered the powerdvd filters and tried both dscaler and the GPL mpeg1/2 decoder filters. Again both enabled win media player to play the files fine, but xnview would not create a thumbnail for the files. I made sure to delete the cache for the directory I was testing with, each time I change codec.
I am using XP x64 SP2 and xnview v1.91 if that is any help.
Re: Can xnview generate thumbnails from mpeg 2 files?
Which extension do you have?ph0b0s321 wrote:Thanks for creating this brilliant program. I use it both on my desktop and pocketpc. I wanted to confirm though, if Xnview supports making thumbnails of mpeg2 and realmedia files?
phobos
Thanks for the reply. The files that xnview is not generating thumbnails for are .mpg, .mpeg and .rm extensions.
Xnview generates thumbnails for some .mpg and .mpeg files and not for others. After checking into it I found that it generated thumbnails for mpeg 1 encoded .mpg and .mpeg files, but not for mpeg 2 encoded .mpg and .mpeg files. Hence my original posted question about movie codec support.
I also tried changing the extension on some of the files to .mp2 and .m2p, but xnview still would not generate any thumbnails for those files....
XnView use DirectX to create thumbnail, do you have a filter for mpeg2?phobos wrote:Thanks for the reply. The files that xnview is not generating thumbnails for are .mpg, .mpeg and .rm extensions.
Install FFDShow and enable MPEG2 support in FFDShow.
You can download FFDShow here - http://sourceforge.net/projects/ffdshow-tryout/
phobos
Thanks for all the suggestions. I have used the 3 directshow, directx, codecs for mpeg2 decoding listed in my original post. Normally I use windows media player to tell me if a directx codec is installed, as if not it won't play the file.
Anyway after the last suggestion I got ffdshow. I deinstalled, de-registered all other mpeg2 decoders. To check I tried to open the movies with windows media player, but it would not work.
I then installed ffdshow. I again tried to play the movie with windows media player and it worked. When I look at the 'properties' for the file, windows media player tells me it is using ffdshow. So it looks like were set.
Unfortunately XNview still will not generate thumbnails for the mpeg2 encoded files.
phobos
Not easily, but I just downloaded these two files and they behave in the same way, so can be used to test.
http://www.jhepple.com/support/SampleMovies/MPEG-2.mpg
http://www.jhepple.com/SampleMovies/Sta ... PEG-2.mpeg
Again, I have no problem playing these files. And I am not trying to edit them. I am just trying to get Xnview to generate a thumbnail for them the in file browser window with the other types of movies .wmv, .avi and .mov, all of which can be seen as thumbnails without problem.
Ok, i'll fix itAnonymous wrote:Not easily, but I just downloaded these two files and they behave in the same way, so can be used to test.
Thanks.
Also are there any plans to support realmedia / realplayer video's , if not already? Realplayer also uses a directx / directshow filter as well. But I assume XNview does not class .rm files as movie files at the moment. When I select one the, text insided the file comes up in the preview window rather than the video....
I remember that MPEG 2 thumbnails were supported, but there was a strange green effect, I think it was also correct in some old version, not sure if it was a codec, or xnview.
Anyway, what about the TS files? It's also the MPEG2 - with more information (more audio streams, teletext, EPG...), recorded by some DVB players.
Dreamer
RM is a video for XnView, so if you have the DS filter, this must work. But perhaps the same problem as mpg2 that don't support classic way to extract thumbnail...Anonymous wrote:Thanks.
