Cannot overwrite hidden image
marsh
Post by marsh »
If an image's property is set to hidden, it cannot be overwritten using 'save' <ctrl +s>. The warning dialog "Error creating the file xyz.gif" is shown.
When the same image is rotated clockwise with the browser's toolbar button, the hidden attribute is not preserved.
v.1.91
Re: Cannot overwrite hidden image
marsh wrote:If an image's property is set to hidden, it cannot be overwritten using 'save' <ctrl +s>. The warning dialog "Error creating the file xyz.gif" is shown.
The file must be overwrited??
So the file must be hidden after that, right?
marsh
Post by marsh »
Yes, because of the unexplained error dialog. The 'read-only' attribute is a better way of protecting files (where a friendly dialog is shown at overwriting attempts). I think the 'hidden' attribute in generally useless, and I only tried it because of some other visotor's comment. :)
Preserving original attribute would be better. Maybe a small number of users would use this as yet another means of organizing files in same folder.
