1.91: Wrong Tooltip
Bugs, defects, GPFs. Nothing else.
Moderators: Olivier_G, Dreamer, XnTriq, helmut, xnview
1.91: Wrong Tooltip
Postby Danny » Fri May 25, 2007 8:16 pm
Steps to reproduce:
- Setup tooltip to show Filename with extension but without path
- open a folder with subfolders
- choose to view files in subfolders
If you now hover over a movie file, it will display the filepath in the tooltip anyway. Not for image files though.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Danny
Postby XnTriq » Fri May 25, 2007 9:10 pm
Here are my settings in Tools » Options... » Browser » Browser » Show tooltips:
<Filename With Ext>
<Width>x<Height>x<BPP> · <Size>
<Modified>
For images the information is displayed as expected, ...
1024×768×24 · 1.234.567
30/Feb/2007 20:07:30
... but with videos the tooltips are formatted differently:
video.mpg, 1234567 bytes, 30.02.2007 20:07
Hence I can confirm some kind of bug for v1.91, although I don't get the filepath.
Moderator & Librarian
Re: 1.91: Wrong Tooltip
Postby xnview » Sat May 26, 2007 7:09 am
Danny wrote:Steps to reproduce:
For video, i don't use the tooltips from option, because there is many things that are not the same as picture...
Postby Danny » Sat May 26, 2007 12:14 pm
xnview wrote:For video, i don't use the tooltips from option, because there is many things that are not the same as picture...
I see, but why is the tooltip correct for video files in the current folder? It only becomes wrong for files that are stored in a subfolder of the current one.
Danny
Postby xnview » Sun May 27, 2007 1:58 pm
If you use 'show files in subfolders'??
Postby Danny » Sun May 27, 2007 7:26 pm
xnview wrote:If you use 'show files in subfolders'??
Yes.
Danny
Postby Danny » Sat Jan 26, 2008 10:02 pm
So, how is it? I still get wrong tooltips. Even the default setting only shows the first line of the tooltip. And if i change it, it's still the same as the default setting.
Danny
Postby xnview » Sun Jan 27, 2008 7:40 pm
Danny wrote:So, how is it? I still get wrong tooltips. Even the default setting only shows the first line of the tooltip. And if i change it, it's still the same as the default setting.
You have always the bug with 1.91??
Postby Danny » Mon Jan 28, 2008 6:42 pm
Ok, i figured out why. I have "Scan file headers" only for fixed discs, so it won't scan files on the local network. :|
But it's unexpected that it won't show things like the file path, since that's not part of any file header. This is especially useful for the "Show files recursively" command to quickly find out in which folder a particular file resides in though.
Danny
Return to Bug Reports
Who is online
Users browsing this forum: No registered users and 0 guests
