IPTC write to all not working
walhalla
Post by walhalla »
hi,
i tried xnview (latest version for win / 1.91) and i am really happy. but one thing does not work: writing iptc-data to more than one picture.
- i mark several pictures
- press "strg - i" for edit iptc-data
- fill out some fields (caption, remarks, ...)
- press "write to all"
now my pc is doing something ... it takes some seconds (i can hear the hd work). if it is ready, all fields in the iptc-window are empty again and i cant see any iptc-ionformation in the pictures. in the browser i can see this little sign "iptc" on the bottom of the thumbnails - in preview is no register iptc.
writing the data to one picture works - but with several pictures (i tried with 3, 10, 20, 100) it is not working. why? what can i do that it is working because xnview is beautyfull and fast! but without this function senseless for me :(
thx for any hint or solution!
jens
Re: IPTC write to all not working
walhalla wrote:hi,
Strange, the selected pictures have already IPTC data before to edit IPTC?
Post by Guest »
[/quote]
Strange, the selected pictures have already IPTC data before to edit IPTC?[/quote]
hi & thx for your fast response! no, the images did not have any IPTC-data before.
walhalla
Post by walhalla »
[quote="xnview"]
jens
walhalla wrote: hi & thx for your fast response!
I've tested on 2 pictures with iptc, and all is ok...
Which settings do you have for IPTC writing?
walhalla
Post by walhalla »
[quote="xnview"][quote="walhalla"]
[/quote]
Which settings do you have for IPTC writing?[/quote]
i tried all possible settings! if you want, you can watch my pc with netviewer (therefor i should have your email-address for sending the sessioncode).
jens
walhalla wrote: i tried all possible settings! if you want, you can watch my pc with netviewer (therefor i should have your email-address for sending the sessioncode).
Please send me or post 2 or 3 of your pictures?
walhalla
Post by walhalla »
where should i send this pictures? each of this images has about 5mb size!
walhalla
Post by walhalla »
hi,
i uploaded some images. you can download from there:
thanks for your help!
jens
walhalla wrote:hi,
jens
I've tested with these files, i've entered something in caption, use 'combine new & current', and the 3 others settings are enabled too, click on 'write all' and all works... I have the good caption in all pictures....
walhalla
Post by walhalla »
hi & thx very much!
i tried again and used the only thing, i have not tried before: i tagged all therr options at "combine..." -> "add new ...", "keep current ..." & "replace ...". it works (ONLY), if all options are tagged!?
i dont understand, but now i know and so i can keep on trying your software!
merci beaucoup!
jens
p.s.: could you please remove the link to the pictures from your post! thx
walhalla
Post by walhalla »
last question regarding IPTC: is there any qualityloss if writing this data in the image? lossless working, that no quality/data gets lost?
thx
jens
walhalla wrote:hi & thx very much!
i dont understand, but now i know and so i can keep on trieing your software!
Ok, if 'Replace only if current value is empty' is not enabled, there is a problem... I'll check...
