Crash when displaying MJPEG encoded files
Post by Guest »
I haven a digicam Canon Powershot S30. Its videos are MJPEG encoded.
The thumbnail preview of xnview is correct but when clicking on that file, xnview crashes:
OS: WinXP Professional SP2
XnView 1.91 / 16 may 2007
AppName: xnview.exe AppVer: 1.91.0.0 ModName: subtitds.ax
ModVer: 1.4.0.0 Offset: 000041b1
technical information of this bugreport of windows:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="xnview.exe"
I can send this info of windows if you want (xml-file)
Re: Crash when displaying MJPEG encoded files
Anonymous wrote:I haven a digicam Canon Powershot S30. Its videos are MJPEG encoded.
<DATABASE>
Could you post a file, please?
Post by Guest »
Since i don't know how to post files here, you can download it here:
http://www.k10.zschenker.net/html/dateien/MJPEG.avi
the bugreport of winxp:
http://www.k10.zschenker.net/html/datei ... compat.txt
greets
and thank you for your hard work! great prog :)
No pb
:arrow: Guest
:) Hello !
• I saved and tested your sample here in XnView 1.91, that works like a charm…
- Win XP-Pro SP1 (Fr-Eng.)
:mrgreen: Kind regards,
No problem on Xp SP2 too
Danny
Post by Danny »
No problem here either (WinXP SP1). Probably a codec issue. You should deinstall all codecs that you don't need. Codec packs often hurt more than they help.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Post by Guest »
curious that this forces xnview to crash. but you are right it was a codec issue. (no codec pack)
thanks!
