EXIF image rotation for Olympus images
szaki6
Post by szaki6 »
XnView does not autorotate Olympus images.
example http://www.szathmari.hu/P8110667.JPG
Re: EXIF image rotation for Olympus images
szaki6 wrote:XnView does not autorotate Olympus images.
It's normal, there is no EXIF orientation
kpacu
Post by kpacu »
What is wrong with Olympus exif info so xnview does not autorotate images from this cameras?
oops66
Post by oops66 »
With "olds" digitals camera (not only Olympus), the EXIF version do not support the orientation field, then you can not use auto-rotate from exif under XnView or others softs that supports this function.
In this case you can manually do by hand, in "Tools"\" JPEG lossless transformation" \ "rotate 90° right" or left or ...
And under tools\options\browser\misc.\
change exif orientation(if possible) = on
use lossless orientation when (if possible) for jpeg = on
Post by Guest »
What you mean "old" it's a brand new camera model 2007?
And there is an orientation field in the exif:
Image description : OLYMPUS DIGITAL CAMERA
Camera Manufacturer : OLYMPUS IMAGING CORP.
Camera Model : u850SW,S850SW
Orientation : top-left (1)
X Resolution : 314
Y Resolution : 314
Resolution unit : Inch
Software : Version 1.0
Date modified : 2008:07:07 11:42:43
YCbCr Positioning : co-sited (2)
Exposure time : 1/30
F-Number : 3.5
Exposure program : Creative (slow) (5)
ISO speed ratings : 100
EXIF version : 02.21
Date taken : 2008:07:07 11:42:43
Date digitized : 2008:07:07 11:42:43
Components configuration : YCbCr
Exposure bias value : 0
Max aperture : F3.5
Metering mode : Multi-segment (5)
Light source : Unknown (0)
Flash : Flash fired
Focal length [mm] : 6.7
FlashPix Version : 01.00
Colour space : sRGB
EXIF image width : 3264
EXIF image length : 2448
Interoperability offset : 614
File source : DSC
Custom rendered : Normal process (0)
Exposure mode : Auto (0)
White balance : Auto (0)
Digital zoom : 1/1
Scene capture type : Standard (0)
Gain control : Low gain up (1)
Contrast : Normal (0)
Saturation : Normal (0)
Sharpness : Normal (0)
IOP index : R98
IOP version : 0100
Compression : 6
X Resolution : 72
Y Resolution : 72
Thumbnail offset : 8980
Thumbnail length : 6604
oops66
Post by oops66 »
I think that your exif Orientation field always stays at "top-left (1)" in all cases !
NO ????
Just for info:
http://sylvana.net/jpegcrop/exif_orientation.html
Orientation: top-left (1)
Post by Guest »
Yes, i believe that orientation is same top-left for all images. As far i undrstand that i must manualy rotate images of my camera because it lack orientation sensor or something. Thens anyway for help.
oops66
Post by oops66 »
Yes your camera problably does'nt have a mercury orientation sensor, and you have to do this orientation by hand (lossless is better).
