Bug in 'Save changed file' dialog
Post by Guest »
Hi all.
v1.91, W2k
I've found the following issue: if I change file and press PgDn then focused key ('Yes') in 'Save changed file' doesn't work.
Steps:
1) Open picture in viewer.
2) Rotate picture.
3) Press PgDn. Now dialog 'Save changed file' is on screen, button 'Yes' has focus.
4) Press 'Enter' - dialog disappears.
5) Press PgDn and see dialog again (i.e. dialog had no effect).
If you click button with mouse or move focus on another button and on 'Yes' again then next dialog ('overwrite') appears as expected.
Alex.
marsh
Post by marsh »
Confirmed.
