Paint plugin - resolution problems
rockstar1707
Post by rockstar1707 »
I'm using XnView on a laptop with the resolution 1920×1200 pixels and NVIDIA Quadro NVS 120 M graphic card.
However, when I open a picture with the Paint plugin, i got some "defects" on the upper left corner, as shown on the screenshot attached below.
I'm wandering if this is the problem of graphic card, or is has to do something with the Plugin. I tried Paint on a standard PC, with the resolution 1280×1024 pixels, and it worked OK.
Otherwise the plugin works ok, just the screen is a bit scrambled.
Image[/img]
Re: Paint plugin - resolution problems
rockstar1707 wrote:I'm using XnView on a laptop with the resolution 1920×1200 pixels and NVIDIA Quadro NVS 120 M graphic card.
You have this problem even if you are in fit window?
rockstar1707
I don't know exactly what do you mean.
If this refers to zoom inside of Paint plugin window, than the answer is yes. The same "scrambled" screen appears even if I choose "Fit to window" or some other zoom in.
If you minimize and restore the window, you have always this problem?
rockstar1707
Yes, this happens in any case. See attached screenshot.
Do you use standard DPI (96) for the screen or something like 'big font'?
rockstar1707
Fonts are normal size, but it's true that the DPI is set to 120. Maybe this could be the problem than.
JohnFredC
Post by JohnFredC »
Hi Pierre
I have had exactly the same problem ever since you introduced the paint plugin.
1920x1200 120dpi
John
rockstar1707
Great, in version 1.91.3 this is fixed :)
Thank you very much for such a fast "intervention" :)
BTW, great program.
