New capture command line options issues
Dreamer
Post by Dreamer »
I have reported these issues/bugs in the other topic in the Suggestions group. I have created the new topic in this group instead of split the old topic.
New capture command line options work like this in the final version (1.91.2):
A
When I use -capture=desktop,e:\test.jpg and "directory" capture setup option, screenshot is saved correctly, but just a single one can be created this way, others replace the original one.
B
When I use -capture=desktop and "directory" capture setup option, screenshot is saved correctly, but the viewer windows just blinks and then browser window is shown - no xnview windows should be shown in this case, since I use option to save the screenshot, not open in xnview.
C
When I use -capture=desktop and "open in xnview" capture setup option, screenshot is not saved (not a bug), xnview window is smaller, the viewer windows is not maximized and it's shrinked.
What I've suggested and what I need, is to be able to create and save the screenshot and exit xnview - A is close, but just a single screenshot can be created, B is close too, but xnview exit is missing. C should save the screenshot first, then open it in viewer, but this is not so important.
Dreamer
Re: New capture command line options issues
Dreamer wrote:A
It's normal, you must use '#'
B
Here i have only the browser, no view window...
C
Ok
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:A
Thanks, but:
- how should I know that? ;)
- it doesn't work :bug: , just the first file is created, no "2"nd file, tested with desktop and window
Is it possible to use a date (and time) here somehow?
xnview wrote:
B
Viewer window's just blinks, it's hard to see that, but it's a bug though, isn't it? When I use "Save to Directory", not "Open in xnview", xnview should exit at the end.
Dreamer
Dreamer wrote:
xnview wrote:
Dreamer wrote:A
Thanks, but:
You have asked for that :-)
Are you sure, i've checked and there is a new file each time!
Currently no
xnview wrote:
B
There is no viewer window, i've checked....
For the exit after saving, i don't know. Is it good??
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:
xnview wrote: It's normal, you must use '#'
Thanks, but:
I have asked, per mail, your reply:
"-capture=window
-capture=desktop
-capture=window,c:\file.jpg"
I can't see any "#" here. :wink:
OK, it works if an extension in Capture dialog and command line option is the same, if it's not the same, the first file is created, but the others not.
Perhaps something like ".ext" might be used, than extension from Capture dialog would be used, otherwise we must change it in the Capture dialog and command line option.
Currently no
Could you add such an option please? Something like <date> <time>, or just "$" for date and time.
xnview wrote: Here i have only the browser, no view window...
Because there is also the option "Open in xnview", it's enough IMO and you can't create the other screenshots even thought, since xnview window is active, so exit would be the best, you can choose if you create more screenshots then.
Exit would be useful if want to:
- create more screenshots by a hotkey
- use a scheduler to make screenshots every hour, minute...
Perhaps these options might help:
http://newsgroup.xnview.com/viewtopic.php?p=51062#51062
These:
"After capture do this:
[ ] Save the image
[x] Open the image in Viewer
[ ] Open the image(s) Browser
[ ] Exit
Save directory [ . . . . . . . . . . ]
Format [ . . . . . . . . . . ]
Or, the best - the independent command line options:
save (to save and exit)
open (to save and open in viewer) *
browse (to save and open capture dir. in browser)
* If not possible, just open.
For example:
-capture=desktop,save
-capture=desktop,open
-capture=desktop,browse
However, "browse" wouldn't be very useful IMHO.
Edit:
I can definitely see it, when using these Capture setup dialog options:
- Desktop
- Hide xnview
- Multiple capture
- Save - Directory
and these command line option:
-capture=desktop
Dreamer
Dreamer
Post by Dreamer »
Another problem. :(
D
I can't create an active window screenshot, even if I select "Active window" in the Capture setup dialog. I'm sure the window is active. I'm using this command line option:
Desktop screenshot is created every time, instead of active window.
Edit: I works good when I use a Capture setup dialog and hotkey, but command line option doesn't work.
Dreamer
Ok, i check
Ok, i'll add $
But if you want to exit after the capture, so you can use the command line!!
- Desktop
- Hide xnview
- Multiple capture
- Save - Directory
-capture=desktop
You means viewer window or xnview window??
Dreamer wrote:I can't create an active window screenshot, even if I select "Active window" in the Capture setup dialog. I'm sure the window is active. I'm using this command line option:
Sorry i don't understand the problem...
Dreamer
Post by Dreamer »
Ok, i'll add $
Thanks.
OK, but how??
I can definitely see it, when using these Capture setup dialog options...
Viewer windows is shown for a moment, it looks like it would be minimized and restored - I can see such an animation, Viewer is shown and then it's changed to Browser immediately. But this is not so important...
Dreamer wrote:D ...
OK, I see that when I'm using this:
-capture=window
Active window screenshot is created - correct.
But when I'm using this:
(or -capture=window,c:\screenshot#.jpg)
Desktop screenshot is created, instead of active window - :bug: .
Dreamer
OK, but how??
If you use -capture=window, c:\file.jpg, xnview exits after capture!!
Strange, i have not this problem!
Dreamer wrote:D ...
-capture=window
Right
Dreamer
Post by Dreamer »
xnview wrote:If you use -capture=window, c:\file.jpg, xnview exits after capture!!
Oh right, with "$" it will be enough.
Dreamer
Dreamer
Post by Dreamer »
I have tested v1.91.3, results:
All bugs have been fixed except these:
- When I use -capture=desktop and "open in xnview" capture setup option, xnview's viewer window size is changed, it's smaller, window position looks correct, but it's quite annoying, since viewer window size is lost after each capture.
- I still can see the viewer window before browser, but it's a very minor issue, never mind.
- $ (date_time) has been added, thanks, but the new command line options have not been added to Command line help, these options are very useful, but there is no information, even in the changelog, e.g. "$", so just few users can use them.
Anyway, -capture=window,d:\screenshot$.ext works perfect now, thank you very much for that, Pierre!
Dreamer
Dreamer
Post by Dreamer »
Another minor bug:
- When I use -capture=window,d:\screenshot$.ext for example, the cursor is always included, also if "Include cursor" option in Capture setup dialog is disabled.
Dreamer
Dreamer
Post by Dreamer »
v1.91.4
XnView is opened in fullscreen now, but when I switch to window mode (viewer), size is still changed - always.
It looks the cursor is not included when using just -capture=desktop, but it is still included when using -capture=window,d:\screenshot$.ext.
Dreamer
I can't reproduce, the cursor is not included in the 2 cases if 'include cursor' is not checked in the capture dialog...
Dreamer
Post by Dreamer »
Strange, I can always reproduce this bug, with both:
and -capture=desktop,d:\screenshot$.ext
Make sure the cursor is within the window, or try "desktop".
Dreamer
