vidéo flash *.flv under Xnview
oops66
Post by oops66 »
It will be a nice improvement to have Xnview able to read flv vidéo file.
fichiervideo.flv (vidéo flash Macromedia from daylimotion, youtube etc...)
maybe with open source :ffplay ; ffmpeg ?
XnViewMP Linux X64 - Debian - X64
See the French forum
—> oops66
:) Hello !
• That works already, you have just to install the right codecs…
• This has been largely discussed in the French forum, just search for ;)
:mrgreen: KR
oops66
Post by oops66 »
2Clo
Merci, j'avais pas vu !
This big file, I presume !
http://newsgroup.xnview.com/viewtopic.p ... hlight=flv
"K-Lite Codec Pack 2.88 Full" : the last for windows 9X ...
http://www.free-codecs.com/download/K_L ... c_Pack.htm
now: K-Lite Codec Pack 3.3.0 FULL version : for xp 2k...
ckit
Post by ckit »
Better off using FFDShow than codec packs.
You can get FFDShow (CLSID's version) here - http://sourceforge.net/projects/ffdshow-tryout/
oops66
Post by oops66 »
2ckit
Thanks, ffdshow is better and smaller, especialy under win98 ( and it's up to date for win9X users).
It works with Xnview better in my case (like ffplay).
ffdshow_rev1413_20070809_xxl.exe
Drahken
Post by Drahken »
You might have trouble with the more recent FLV4 files. While many programs can handle FLV1 files, few can do FLV4. You know you have this problem if you play an FLV file and just get the audio. To fix this, you need to use an FLV splitter. This one works great: http://ffdshow.faireal.net/mirror/Media ... plitter.7z
If you have that and FFmpeg installed, you should be able to play all FLV files on just about any player on your system.
oops66
Post by oops66 »
2Drahken
Thanks for your technical information.
Yes, I had this problem (strange noises and black vidéo) with the
K-Lite Codec Pack 2.88 Full ( the lastest version for windows 9X ..) but it was solved by using the ffdshow_rev1413_20070809_xxl.exe program.
(except the location of the vidéo windows area on xnview - always at the top-right of the screen, like ffplay behavior).
But it works even with FLV4 files - I suppose (recent daylimotion flv file)...
Yes I have also FFmpeg installed with ffplay.
Drahken
Post by Drahken »
I actually meant to say FFdshow anyway. The version of FFD i installed worked for FLV1, but not FLV4, I had to get the splitter for that.
