Exif problem to Pentax K10D PEF-Files
Nutznieser
Post by Nutznieser »
Hallo
For Pentax K10D PEF-Files will not showed some exif informations. They are: 'Iso speed ratings' and 'exposure bias value' and 'focal length'
I work with XnView 1.91.3 and with WinXP Home/Professional.
HarryH!
Re: Exif problem to Pentax K10D PEF-Files
Nutznieser wrote:Hallo
Could you send me a sample?
Nutznieser
Hallo Pierre,
xnview wrote:Could you send me a sample?
How? Should I send you an email? (File size is ca. 9MB)
HarryH!
Nutznieser wrote:Hallo Pierre,
On webmaster at xnview dot com
Nutznieser
Hallo Pierre,
I have sent you a K10D PEF file.
HarryH!
Ok, i'll try to add these fields
Birdman
Post by Birdman »
Hi Pierre,
any news on this? I am using the 1.92 and the iso value still is not recognized by XnView for Pentax PEF-files.
Birdman
Birdman wrote:Hi Pierre,
Birdman
These values are in EXIF Makernotes, currently you can not use these fields, but i'll add them
Birdman
Post by Birdman »
xnview wrote:These values are in EXIF Makernotes, currently you can not use these fields, but i'll add them
Do you mean that the ISO value from JPG- and PEF-files out of Pentax cams are stored in different exif tags? I compared both type of files with Phil Harveys exiftool and they both seemed to be stored in the exif:ISO.
Really? Which files do you have sent me, to check again?
Birdman
Post by Birdman »
xnview wrote:Really? Which files do you have sent me, to check again?
I will send you an original pef-file. There are several ISO-tags, the one I mean in Exiftool is called [EXIFIFD:ISO]. I altered it in a jpg and in a pef-file, so both are showing 3200. In XnView the jpg is displayed correctly with "3200", the pef still with an "0".
