1.91.3: Two Cache Sizes?
ckit
After pressing "Optimize" in the Cache dialog there are 2 cache size readings, is this new normal behaviour or a bug?
Seems OK
—> ckit
Hello Chris !
• This seems normal, since it displays the old and the new size, showing the eventual gain @ size you got by optimizing.
- I tested at this moment, I get smaller by ~ 3 MiB. I think it's a good useful feature.
- When you close the box, then come back to it, you read only the current size…
KR
Grzesiek
Limit forgotten---
—> Grzesiek
Hello !
• Right, but this is not a normal using…
- Maybe Pierre might set a limitation for one button stroke only… ?
KR
ckit
Re: Seems OK
I agree it seems normal however having the second one called "Optimized size:" instead of "Cache size:" would be better.Clo wrote:—> ckit
Hello Chris !
KR
