Could you add aspect ration 16:10 (1920x1200) for wide screen TFTs to the image editor. There is no way to enter a new apect ratio to make a wallpaper for 1440x900 or 1920x1200 TFTs.
Another method to make a windows wallpaper would be to add an option for the background picture to cut the picture (not to stretch), if the aspect ratio of the picture is not the aspect ratio of the monitor.
Thanks a lot ...
add aspect ratio 16:10 (1920x1200) for wide screen TFTs
Tim
Re: add aspect ratio 16:10 (1920x1200) for wide screen TFTs
In resize dialog??Tim wrote:Could you add aspect ration 16:10 (1920x1200) for wide screen TFTs to the image editor. There is no way to enter a new apect ratio to make a wallpaper for 1440x900 or 1920x1200 TFTs.
Thanks a lot ...
Tim
Edit Dialog
Hello, i mean the "Edit" Dialog, in the german version of xnview:
[/list]
[/list]-
Dreamer
