Hello Pierre,
Will you support Panasonic / Leica EXIF Tags in a future version of XnView?
Please, see here:
http://www.sno.phy.queensu.ca/~phil/exi ... sonic.html
Latest version from Aug 20, 2007 decoded a number of new Panasonic tags, and added a number of new SceneMode's.
Thank you very much for your great XnView which is better and better with every release!
PS: I am using XnView v1.91.4.
Panasonic EXIF Tags
Re: Panasonic EXIF Tags
Could you send me a panasonic file?jis wrote:Hello Pierre,
Please, see here:
jis
kristopulo
Hi guys,
As true fan of your software, I used to do for friends slideshows with extra information taken from exif/iptc data. However last month I bought Panasonic tz10 with geotagging option and there is problem with displaying these information. Longitude and latitude are available BUT panasonic tz10 add also extra 3tags: country, city and landmark. Is it possible to display it during slideshow/fullscreen mode?
best regards
kris
best regards
kris
Could you send me a sample?kristopulo wrote:Hi guys,
kristopulo
Hi Pierre,xnview wrote:Please try XnView 1.98 beta 1
Looks now mentioned tags are visible at main screen(EXIF TAB), however I can not make them visible for fullscreen mode
please check: http://krzysztof.biz/fullscreen.jpg
If you means Makernotes, it's not possiblekristopulo wrote: Looks now mentioned tags are visible at main screen(EXIF TAB), however I can not make them visible for fullscreen modeNames of tags(location,country,state,landmark) are identical as for last option (IPTC:Origin) but it does not show these informations
What am I doing wrong?
kristopulo
My I ask what is the problem with that? Any technical issue? Or Panasonic names are not "ISO standards" so You do not want to put into menu option for every manufacturer who made cameras with GPS?xnview wrote: If you means Makernotes, it's not possible
During fullscreen slideshow these information from tags are extremely usefull because you dont have to think where was this picture taken, or what is this building name...
kaclem
what is this?if you means Makernotes
EmilyWatson
The EXIF standard allows camera vendors and others ("makers") to add proprietary data to the EXIF record stored - the so-called maker notes. The EXIF meta data Standard describes how cameras and other imaging devices can embed information about the image inside the image. This data area is not standardized and hence each camera vendor stores different information in this area. Unlike the EXIF data itself, maker notes are undocumented and proprietary.kaclem wrote:what is this?if you means Makernotes
TinyMiner EVE mining bot - Autopilot Profits in EVE Online for billions of ISK! It's definitely the best option out there in terms of EVE Online mining bots. TinyMiner has a fully functional mining bot trial version so you simply can't go wrong!
