Currently I click on every folder name, which is not ideal. A "go to next folder in tree" shortcut key would be awesome.
Thanks for the great software!
Yes, normal, there is a delay when you navigate by key. Dreamer do you have a hotkey for 'next folder'?phnxw wrote:Currently I click on every folder name, which is not ideal. A "go to next folder in tree" shortcut key would be awesome.I know I can highlight a folder and press the up or down keys, but there's a delay of about 1 second before the new folder is loaded.
I want it to load immediately.
