Pane collapsing bug
ilgaspa
Pane collapsing bug
Post by ilgaspa »
VERSION: 1.91.4
OS: Windows XP Professional SP2
Collapsed panes aren't restored correctly when closing/opening xnview
STEPS TO REPRODUCE
1. Set layout to third option (treebar on the left, proprieties under the treebar , thumbs on the right)
2. Collapse the whole sidebar (treebar + proprieties) by clicking the little arrow pointing left
3. Close XnView
4. Open XnView
5. Everything seems alright (the panes are still collapsed as they should be) but pressing the little arrow to restore them does nothing
BUG-IN-THE-BUG ( ;-) )
6. Force the opening of the side panel by pressing CTRL+ALT+F
7. The side pane is opened again, but with wrong dimensions (not the one it had at step 1
BUG-IN-THE-BUG 2
8. At this point, the proprieties pane is collapsed to the bottom of the screen, yet we never collapsed it and it shouldn't be
JohnFredC
Post by JohnFredC »
This has been a nagging issue for Layout #7 since it's inception.
John
ilgaspa
Post by ilgaspa »
Well, at least I know it's not only my problem :) Is there any known workaround?
