Or perhaps bad documentation.
The help file says that the punctuation characters used for short cuts (+, -, *, /) work the same whether entered from the numeric keypad or from the regular keyboard.
" Control / ", however, does NOT work like this. It only works (zoom lock, for next image) if the numpad "/" is used.
Is this a problem with XnView or with the doc?
