"Find similar files" - how to use it?
I tried the function "Find similar files" - and no matter which method I'm using (name, data, picture) - I get always the same result: "No files found".
At the end I copied "a.wmf" to "b.wmf" and "c.wmf" in the same directory - no results.
What is wrong?
Peter
What is wrong?
Peter
Re: "Find similar files" - how to use it?
You have added a folder?Peter2 wrote:I tried the function "Find similar files" - and no matter which method I'm using (name, data, picture) - I get always the same result: "No files found".
What is wrong?
Yes - of course. I started in the directory, removed and added it again - no results.xnview wrote:You have added a folder?
Is there a limitation on special filetypes? I have wmf, sld (AutoCAD) and dwg.
Peter
Oh, yes works only with picture filesPeter2 wrote:Yes - of course. I started in the directory, removed and added it again - no results.xnview wrote:You have added a folder?
Pierre, what are "picture files"? Raster data Itif, jpg, bmp)? WMF is also a "picture", but vector ..
Peter
PS: This function is missing in Online-help.
Peter
I means raster data...Peter2 wrote:Pierre, what are "picture files"? Raster data Itif, jpg, bmp)? WMF is also a "picture", but vector ..
Sorry - I tried again:
one directory with 1300 tifs and 107 MB
"Same file data" - after half a second: No files found.
"Similar picture" (similarity 54) - after half a second: No files found.
I copied "a.tif" to "b.tif" - No files found.
Peter
Peter
Strange, i've tested with jpeg & tiff, it works correctly.Peter2 wrote:Sorry - I tried again:
Could you send me your a.tif to check?
Fixed in Version 1.91.5, October 5, 2007:Peter2 wrote:.."Same file data" - after half a second: No files found.
http://newsgroup.xnview.com/viewtopic.php?t=13573
Works not on B&W-Pictures.Peter2 wrote:.."Similar picture" (similarity 54) - after half a second: No files found.
Peter
