Help with XnView Portable
ckit
Post by ckit »
I'm making my own XnView Portable (the U3 version is crap) but I need new switches!
- xnview portable.cmd
@echo off
xnview.exe -ini xnv_port.ini
exit
- xnv_port.ini
- xnv_port.bar
I need a "-bm <file>" for Bookmarks (mine will be xnv_pbm.ini)
I need a "-cat <file>" for Bookmarks (mine will be xnv_pcat.ini)
and I'm probably still forgetting other things but I'm half-way there :)
ckit
Post by ckit »
Forget that... I forgot about "Folder for other files" option :)
ckit
Post by ckit »
OMFG, XnView removed my local "bookmarks.ini" file and moved it to my USB drive.
Now, I'm pissed right off!
XnView needs to COPY the Bookmarks file NOT MOVE it.
ckit wrote:OMFG, XnView removed my local "bookmarks.ini" file and moved it to my USB drive.
??? What did you made to have this MOVE???
ckit
Post by ckit »
I changed
"Folder for other files"="User"
to "Folder for other files"="Custom"
ckit wrote:I changed
Ok, yes if you change in the Option dialog the location, xnview will move the file. You must change it in xnview.ini
