I wrote about it quite some time ago but didn't get a response.
http://newsgroup.xnview.com/viewtopic.php?p=45853
Basically, what I would very appreciate to have is a permanent option not to confirm to save the file when I move to the next one. This option when checked stays that way only till the program is closed.
Other permanent option I would appreciate is the last used selection ratio. This option stays the same in one window only. When I need to crop the same way a bunch of files from different folders I have to select the ratio again and again. Permanent option will save a lot of time.
Thanks.
Save More Settings
- foxyshadis
Must've missed it the first time around, sorry, but the first already exists as a hidden feature: http://newsgroup.xnview.com/viewtopic.php?p=45579
It's just not exposed in the GUI.
Thanks foxyshadis. I should've found this earlier. This option is a bit strange. Can't find the difference between modes 0 and 1 and even 129 (the dialog is different but works basically the same). Mine initial value was set to 2. What was that supposed to mean? Why is it not in GIU and why it needs SaveAdvDlg is also a mystery. But anyway, it works great.foxyshadis wrote:Must've missed it the first time around, sorry, but the first already exists as a hidden feature: http://newsgroup.xnview.com/viewtopic.php?p=45579
