1.91.6: Canon 40D RAW Support - FIXED
visceralpsyche
Post by visceralpsyche »
I recently bought the new Canon 40D camera and noticed that the RAW support as of 1.91.5 seems buggy:
It puts a weird pink overlay on each image but does show the image itself underneath.
I figure since the camera is new you may not have access to a RAW image from the camera yet, so I have uploaded one for you so you can use it to perhaps pull out the embedded JPG or otherwise figure out how to view them correctly (10MB RAW CR2 image):
http://www.visceralpsyche.com/misc/web_ ... G_0001.CR2
Thanks for all your work!
Paul
Last edited by visceralpsyche on Sat Dec 22, 2007 7:22 am, edited 2 times in total.
Re: 1.91.5 - Canon 40D RAW Support
visceralpsyche wrote:I recently bought the new Canon 40D camera and noticed that the RAW support as of 1.91.5 seems buggy:
Ok, 'ill check
visceralpsyche
Thanks for the 1.91.6 version but this bug still remains. Just bumping it with the new version number in the thread title.
Cheers,
Paul
ckit
Post by ckit »
I just tried this image and I get the same pink result.
I'm willing to bet it has something to do with "Component Configuration = YCbCr"
oops66
Post by oops66 »
I just tried this image too (IMG_0001.CR2 - 10 530 ko ), and for me all is OK, I do not have this pink result.
Strange!
XnViewMP Linux X64 - Debian - X64
ckit
Post by ckit »
IrfanView 4.10 works great!
PhotoFiltre Studio 9.0.0 produces a green effect!
Use IrfanView until we have proper support for 48-bit images.
ckit
Post by ckit »
oops66, can you post screenshots of your "Camera Raw" and "RAW" settings in Read\Write dialog box?
ACDSee 10 doesn't support this format yet but the developers on the forum say they are working on it.
VSO Image Resizer was updated recently too to support it.
I'm trying to get PhotoFiltre Studio's author to look at it too.
oops66
Post by oops66 »
ckit wrote:oops66, can you post screenshots of your "Camera Raw" and "RAW" settings in Read\Write dialog box?
Here it is some information :
Screenshot of this .cr2 file:
IMG_0001.CR2 - 10 530 ko , without your pink result.
(without the Jpeg compression bellow, the background is perfectly gray)
config. options RAW:
Regards,
Oops66
ckit
Post by ckit »
Ok, given it works on Win98SE it must be a OS related bug with XnView.
s_boy70
Canon EOS400D
Post by s_boy70 »
info: I've got the same pink effect with canon EOS 400D raw pics (.cr2) under Windows XP SP1.
pasta
Post by pasta »
just to let you know. I have the same result. (XP SP2)
visceralpsyche
Fixed in 1.92 - thankyou!
Have a Merry Xmas and Happy New Year :)
Paul
