This occurs in resize dialogue window in XnView version 1.91.5 (and previous versions):
- open image (in window),
- go to "Image"|"Resize",
- in dialogue, "Screen size" write any number to "width" (or "height") input field,
- try to change width/height by clicking on small arrows on side of field,
- nubers in field is now reset to original values (plus/minus one as you changed the values).
Same if you set width and tried to change height by mouse when "Keep ratio" checked.
Values reset to original ones in resize dialogue
bob.b
Re: Values reset to original ones in resize dialogue
I can't confirm. I enter 10 for example in width (print size), click on arrow, the value is now 11 (or 9)...
ckit
Confirmed.bob.b wrote:This occurs in resize dialogue window in XnView version 1.91.5 (and previous versions):
bob.b
I meant "width"/"height" in "Screen size" part of dialogue.xnview wrote:I can't confirm. I enter 10 for example in width (print size), click on arrow, the value is now 11 (or 9)...
The "Print size" works fine - but try to change "Print size" clicking on arrows and NOW click on arrow in "Screen size"...
