1.91.5: Can't handle some BMP images
Pilzfuss
Post by Pilzfuss »
XnView can't handle BMP images (video screenshots) that I created with VirtualDubMod (not VirtualDub).
It worked with older versions.
It looks like this:
These are 2 BMP images created with VirtualDubMod:
http://www.fastshare.org/download/samples.zip
Does anyone have the same problem?
Kind regards
Awful hosting
—> Pilzfuss
:) Hello !
• Sorry, but I can't get the ZIP from your awful host, I get a HTML page with IE¦Maxthon as the archive (!)
and a lot of thingies in German with Opera, but not the ZIP… :(
• Please, attempt to find another way to make the samples available…
:mrgreen: VG
marsh
Re: 1.91.5 - can't handle some BMP images
Post by marsh »
Pilzfuss wrote:Hi,
Disable View>Preview>Use Alpha Channel for better view of sample bmp. Similar discussion here- perhaps that program doesn't create ideal bmp?
Pilzfuss
Post by Pilzfuss »
Hi Clo,
here's is it again ;)
http://rapidshare.com/files/62759259/samples.zip
marsh wrote:Disable View>Preview>Use Alpha Channel for better view of sample bmp.
I think I'm too stupid.
Can't find this option.
Is that still part of v1.91.5 ?
Pilzfuss wrote:Hi Clo,
You have on the browser mode, View/Preview/Use alpha channel or in view mode, view/Use alpha channel. Do you have tried that?
Pilzfuss
Post by Pilzfuss »
Got it working with your help.
Thank you :D
DOS386
32-bpp BMP bug
Post by DOS386 »
YES. XNVIEW seems to no longer display correctly 32-bpp BMP's. Regression bug :bug: ? Converting to 24 bpp helps. :idea:
Re: 32-bpp BMP bug
NTOSKRNL_VXE wrote:> Does anyone have the same problem?
No it's not a bug. The picture has a bad alpha!!
DOS386
bad alpha
Post by DOS386 »
Yeah :-(
http://www.sendmefile.com/00589614
http://file-pasta.com/f/2186.bmp
Pretty difficult to upload and hotlink a BMP - imageshack allows BMP, but force-compresses it to PNG: usually good idea, just not here :-(
But up to 1.90 XNVIEW used to ignore such bad alpha's :-|
Re: bad alpha
NTOSKRNL_VXE wrote: But up to 1.90 XNVIEW used to ignore such bad alpha's :-|
No, 1.90 read bad alpha too, but the option to use it was disabled by default.
