Vertical Spacing in "Strip of Images" does not work!
- Open XnView in Browser mode
- Select Two Images
- Strip of Images -> Vertical Alignment -> Vertical spacing = 9
- The two images are still kissing each other!
1.91.6: Vertical Spacing bug
ckit
If you skip
—> ckit
Hello Chris !
• Confirmed if you skip the second “Add" button, as well with an horizontal layout.
Or else, it works with… another
here :
- With ANY background colour (default or one you chose and set), the background is red, also red and even red !
- I use 16 BPP at screen only. I tested with 32 BPP, same…
Pierre
Good morning!
- In French, the dialogue is quite crappy, a half of the strings for spacings is reduced to some dots…
- IMHO, this could be done as another layout, I fixed it like this…
… And the wording in the menu is back to the antiquated false "…Panorama" (in French)
KR
