1.91.6: Menu in fullscreen/icons and sys buttons shown twice
Dreamer
Post by Dreamer »
I have changed language to Arabic or so by a shortcut, by mistake, then this bug has appeared - I think it was OK before, but I'm just 99.99% sure. I had this bug before, but I don't remember how I have solved it. I think I have just used an old ini file from backup, but I'm not sure and it doesn't work this time.
- rename xnview.ini file
- change language to English, if needed
- in options > general > mode when starting with a file > select "fullscreen - edit"
- open any image file in explorer
= menu is show in fullscreen
- press a middle mouse button to go to viewer
= xnview icon and the system buttons are shown twice
If you can't reproduce, try to change the language by Alt+F12 first, then repeat the steps above.
XnView 1.91.6 (Oct 19 2007) - complete zip version, Windows XP SP2.
Dreamer
Post by Guest »
Yes. There is a bug, not present in previous versions.
Please Fix it
Ana
Post by Ana »
Same bug here :( , please fix it, thanks !.
