Quick Print...
Quick Print...
Post by Guest »
Hi, my work involves printing a lot random images.
I thought of moving to something new from MS Office PhotoEditor, but seems im not abel to.
I need the viewer to be abel to open quickly, crop, remove red-eye, fastrpint with predefined defaults and close. That 80 times in a day on random times.
I cant waste 2 seconds on closing the stupid printer prompt window.
As i notet, that there can be made plugins and additions to toolbar, i hope to find a solution to my problem.
So is it possible with XnView, or is the old MS PhotoEditor unreplacable?
Re: Quick Print...
Anonymous wrote:Hi, my work involves printing a lot random images.
So perhaps a hotkey to start print without print dialog?
Post by Guest »
That would do, tho i preffer a button.
me again
Post by Guest »
i have searched like 3 days now.
the only substance for microsoft Photo Editor, with my issue, is Tubeesview.
http://www.topshareware.com/TubeesView- ... -37974.htm
The print button of this application prints without any prompts, or irritating questions. But i couldnt find how to setup the default printing settings... seems there are none.
So a plugin for XnView would be apprechiated.
Peter2
Post by Peter2 »
Maybe you can define a print command for the right-mouse-button so that you can print the files from MS Explorer?
Peter
Me
no no
Post by Me »
Not a good idea...
if you the same function as "right cligh > Print"
this gives u 10 times more irritating questions.. a whole damn wizard to fill out. Imagne yourself filling out 90 wizards in row with the same settings for every image.
Besides... we are not calling the images from explorer.. its another program that uses default viewer for the particular extension (jpg.gif..).
Soo.. again to clarify.
I need something to.
1) open the image quick
2) print with 1 click and quick
3) zoom/pan/crop
4) close quick
XnView lacks the 2) only...
Could anyone dirct me to where i could learn about plugin making for XnView.. ?
