Canon PowerShoot S1 IS create *.jpg and *.avi (640x480 30fps) files.
In browser XnView select all video files in folder, menu "Batch Rename", template <Modified>, old name is "mov_????.avi", new name is "16000101 000000.avi" must have "20070708 121212.avi".
Tested on Windows XP and Vista.
1.91.6: Batch Rename video files bug
f0r
Re: 1.91.6: Batch Rename video files bug
Sorry, template is Modified Date [Ymd HMS]f0r wrote:... template <Modified>...
Hurrah!
I have found why this unstable error is occur - if before conversion select one or more video files (with play video in preview window) all these files will be converted with date "16010101 060000.avi".
B.Douille
Is one is solved as well since version 1.95
Using file date for video clips :
http://newsgroup.xnview.com/viewtopic.php?t=11226
