*Custom Sort for Thumbs! Exist in Xnview?
Pulky
Post by Pulky »
Hi !!
I can can't find Custom Sort.
Exist in Xnview? :?:
ckit
Post by ckit »
Best way to custom sort\filter is to use the address bar next to the mini toolbar and type say "C:\*.jpg" and hit enter... grrr this doesn't work like xplorer2!!!
Sorry, I'm off to kill someone :)
Re: *Custom Sort for Thumbs! Exist in Xnview?
Pulky wrote:Hi !!
What do you means by custom sort?
ckit
Post by ckit »
I thought he meant just the JPG's or just the BMP's?
BTW why can't I sort via the address bar in XnView?
ckit wrote:I thought he meant just the JPG's or just the BMP's?
Currently not supported, only to enter a path
No search…
—> ckit
:) Hi Chris !
…grrr this doesn't work like xplorer2!!!
• Indeed, I assume that the stuff you have in this FM is a Search field, linked to the “Search” function…
- In TC, there is a command-line field, editable paths on the spot and a very elaborate Search,
but not such a field which could confuse the users.
- Making a Search field from the current address bar might need to spend a lot of programming hours, I guess…
• What about the “Custom” filter in the browser tool-bar ?
:mrgreen: KR
Pulky
I will try to explain!!
Post by Pulky »
I will try to explain. I study English, sorry for my bad English :?
You move and order the tumbs. Its a thumbnails order Custom Sort.
Its like Fast Stone. I saw there.
You can move freely the thumbs. Select and Move up, down, left, right in the browser. Its useful when you rename images.
Re: I will try to explain!!
Pulky wrote:You can move freely the thumbs. Select and Move up, down, left, right in the browser. Its useful when you rename images.
:arrow: to move the mini pictures
Pulky
Post by Pulky »
Is it possible to sort pictures manually within folder.
I have large numbers of old photos that have been scanned in and none of the "sort by " choices meet my needs.
Need to nominate my own sequence. Does not appear possible to drag and drop.
Paddy
Me too!
I would like to sort the thumbnails in the browser window manually by dragging them with the mouse to an individual, custom order and batch rename them afterwards. I think this would be a rather simple but very powerful feature. Could you please consider to add this feature in the near future?
Karl
:D
http://newsgroup.xnview.com/viewtopic.php?t=12199
