I have described the companion files as follows in my XnView.ini file:
[File]
Companion_00=jpg:nef
Companion_01=nef:jpg
With the first entry I discovered that if I click on and delete the jpg image then the equivalent nef file is also deleted (as expected). However the reverse does not follow. I added the second entry to try and resolve this, but it didn't.
Is my setup method (above) incorrect or is this a bug?
PETER
Companion file delete operations
PSHRutPark
