XNView doesn't remember folder/favorites setting
yosmc
On the left-hand panel I like to switch the folder view to favorites only (very convenient if you only want to operate within your photo folder and subdirectories). However, when I exit the program and restart, I am back to the folder view. As far as I am aware this is a bug, because XnView should remember this setting.
INI entry ?
—> yosmc
Hello !
• It seems that's missing, so I think that an INI entry like :
- I support, of course !
Kind regards,
could do the trick, it might not be that difficult to add, I guess…ShowBrowserChoice= (flag)
0 : Current default (Tree)
1 : Favourites
2 : Categories
ouistiti
1 : Favourites
2 : Categories
