Time shifting
Lapinoo
Time shifting
Post by Lapinoo »
Like many photographers, I often forget to set my camera to the correct time date when daylight saving time is applied or when I move abroad.
I would like to be able to correct (in a batch) photos by adding or removing a certain amount of time to the value found in the EXIF and / or IPTC fields.
Re: Time shifting
Lapinoo wrote:Like many photographers, I often forget to set my camera to the correct time date when daylight saving time is applied or when I move abroad.
You have it in 'change timestamp'
Lapinoo
Post by Lapinoo »
My mistake again ;-)
I will have to test it now !
