PNG Opacity
Ian
PNG Opacity
Post by Ian »
I did a search on PNG opacity but found nothing. It seems XNView only supports viewing 32bit PNG opacity - and only against black and seems to need toggling each time an image is loaded. What about 24bit PNGs or 24bit BMPs? Allowing the user to determine the colour with which to blend (or ideally a checkerboard) would be excellent, and having this as the default view for transparency in images. Is this feature on the cards?
Thanks,
Re: PNG Opacity
Ian wrote:I did a search on PNG opacity but found nothing. It seems XNView only supports viewing 32bit PNG opacity - and only against black and seems to need toggling each time an image is loaded. What about 24bit PNGs or 24bit BMPs? Allowing the user to determine the colour with which to blend (or ideally a checkerboard) would be excellent, and having this as the default view for transparency in images. Is this feature on the cards?
Yes :-)
