1.91.6
In Browser
File description is not updated on the status bar after it has been edited with 'Describe...' (Ctrl+D)
1.91.6: Description on the status bar
OK here
• I cannot confirm, I just tested editing a comment via Ctrl+D, the comment is uptated alright in the status-bar.
- 1.91.6 - Win XP-Pro SP1
- In old versions, there was a minor bug in that case :
We had to click anywhere or to display the next image >> Back to the described one to get the update.
vovka
Re: OK here
Hi Claude
i'm using 1.91.6 - Win 2k SP4
the description updates OK in 'Viewer' but when in 'Browser' I have to click on some other image and then return to see the description change.
thanx for your time.
Right in browser
—> vovka
Again !
- So, I can confirm now, we have the old bug (which occured in “View” as well) in the Browser only.
KR
• Right ! I missed it because I don't use the browser a lot……the description updates OK in 'Viewer' but when in 'Browser' I have to click on some other image
ouistiti
Re: Right in browser
The description in the browser was updated in version 1.6.something I was using before.Clo wrote:—> vovka
Again !
KR
BTW: I am using this description function a lot. Actually is one reason I do NOT want to upgrade ACDsee any more. Is there a plan to fix the problem?
Best
Christoph
Already done
• That's fixed already in 1.91.6 and in the 1.92 ß-…
