Compare should use "Embedded Previews"
TD
Post by TD »
I choosed "Embedded Previews whereever it's possible but when I use compare with my NEF-files, it is not using the embedded previews, resulting in weak colors.
It would be nice. if you could change that.
Regards,
Thomas
