Bug in paint plugin
Drahken
Bug in paint plugin
In the paint plugin (ver 1.03), choosing a line width of greater than 20px fills the entire image with your chosen color. The size of the image itself is irrelevant. Anything up to, and including, 20 works fine, but 21 and up error out. The same thing occurs if you have the line width set to 0. This problem occurs with any of the line based drawing tools (line, rectangle, rounded rectangle, and circle), although the text tool lets you set any font size you want without any errors.
Drahken
Drahken
