1.92: Window pos/size save bug
ckv
Post by ckv »
In certain situation XnView main window size / position is incorrectly saved.
See also: http://newsgroup.xnview.com/viewtopic.php?t=15493
Reproduce:
1. Open any picture in view mode and resize the xnview window to size smaller than the screen.
2. Maximize XnView window. (With the button in the titlebar)
3. View the picture in fullscreen.
4. Close fullscreen and restart XnView.
5. Unmaximize XnView window. (XnView window doesn't return to the size before it was maximized, like it should)
Image Image Image Image Image
Note: If you skip step 3 the bug doesn't occur.
ckv
Post by ckv »
Humpty pumpty. :bug:
Still reproducible in XnView 1.93.6 :(
Danny
Post by Danny »
I think maximizing is the problem. That's why i don't do it, but instead resize the browser window to fit the whole screen. This way it works as i expect it.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Dstruct
Re: 1.92: Window pos/size save bug
Post by Dstruct »
ckv wrote:Reproduce:
Exactly. Still happens in 1.95.3 :(
FIXED (1.96)
Dstruct
Post by Dstruct »
and in 1.95.4
fix coming?
FIXED (1.96)
Please try XnView 1.96 beta
ckv
Post by ckv »
xnview wrote:Please try XnView 1.96 beta
Fixed in XnView 1.96 beta1. Thank you Pierre. :D
Can helmut confirm too that this doesn't happen in 1.96 beta any more.
