Conversion and relative path
Jp
Post by Jp »
I often use xnviews for it's mass converting feature.
And what i like is that you can use "absolute path" to do your conversion
I always download my pictures into some folder (ex. myFolder) I open my pictures i select those i want ton convert and in the path i fill ./resized
The result is that my converted pictures are located under /myFolder/resized... and that's what i want!
But the bug occurs under a certain circumstance. Supossing i got two folder A and B containing pictures.
Xnview is not open.
I go in the A foldeer, open one picture under xnview, switch to list mode to select several pictures. I ask for converting those pictures under ./resized...
Once the pictures have been converted, i have my willed folder no problem... But than under the same xnview "session" i go into the B folder, i select several pictures, ask for converting under ./resized, and my pictures are converted under A/resized folder and not B/resized...
This can be anoying if you're manipulating dozens of pictures and not about the same subject...
Do you confirm it's a bug or is it normal and i have to close my xnview after each conversion?
Thanks anyway this product is great and this is just for improvement
Jp
Re: Conversion and relative path
Jp wrote: Do you confirm it's a bug or is it normal and i have to close my xnview after each conversion?
And if you use %\resized ?
But yes, the current pathname must the current in browser...
