Nikon D300 NEF Exif
Nikon D300 NEF Exif
Post by Guest »
When reading exif from Nikon D300 NEF file 14 bits compress without lost, Xnview always reads ISO 0
Re: Nikon D300 NEF Exif
Anonymous wrote:When reading exif from Nikon D300 NEF file 14 bits compress without lost, Xnview always reads ISO 0
Could you send me a sample, please?
Post by Guest »
Hi Pierre!
Here you can download a Nikon D300 NEF file 14 bits compress without lost.
http://download.yousendit.com/C43AF9E95D5E53CF
I will test RAW not compress and compress with lost.
Thanks.
Regards.
Post by Guest »
I found this note the man page of http://www.exiv2.org/index.html
fi | fixiso
Copy the ISO setting from one of the proprietary Nikon or Canon makernote ISO tags to the regular Exif ISO tag, Exif.Photo.ISOSpeedRatings. Does not overwrite an existing standard Exif ISO tag
I think it is the problem to read ISO in NEF files.
Regards.
Ok, will be fix in 1.92.1
