When I used acdsee long time ago, it was very useful ability in its viewer - pressing PgUp & PgDn I could see pictures in some way sorted order. But when I press Space and Backspace - I could see pictures in random order. And that second ability was great - there is nothing more bored, then viewing same pictures all time in the same sequence.
Now I use XnView and it's great. But I still cannot find ability in it to view pictures in random order (not as a slideshow). Could you add such ability in next version? It would be very nice.
And one more thing. Files "descript.ion" are very great. I use them all the time. But as for the russian language - it should be in oem (not as ansi). Most software use it in that way (far manager, older versions of acdsee (when it supported such ability before moving it to strange bases)). Could you add such trigger "Use oem in descript.ion files" in options?
Thanks
random sequence
Re: random sequence
Okval wrote:When I used acdsee long time ago, it was very useful ability in its viewer - pressing PgUp & PgDn I could see pictures in some way sorted order. But when I press Space and Backspace - I could see pictures in random order. And that second ability was great - there is nothing more bored, then viewing same pictures all time in the same sequence.
Do you have changed the default language for non unicode program in windows settings?And one more thing. Files "descript.ion" are very great. I use them all the time. But as for the russian language - it should be in oem (not as ansi). Most software use it in that way (far manager, older versions of acdsee (when it supported such ability before moving it to strange bases)). Could you add such trigger "Use oem in descript.ion files" in options?
Just a box
val
Re: random sequence
Thanks.xnview wrote: Ok
No, I have not. It came from Dos to Windows - using OEM codetable (for russian cp-866) instead of ANSI codetable (cp-1251) in console apps. So you should use CharToOem/OemToChar.Do you have changed the default language for non unicode program in windows settings?And one more thing. Files "descript.ion" are very great. I use them all the time. But as for the russian language - it should be in oem (not as ansi). Most software use it in that way (far manager, older versions of acdsee (when it supported such ability before moving it to strange bases)). Could you add such trigger "Use oem in descript.ion files" in options?
And Clo isn't right fully. It shouldn't be just in editing window - it should be somewhere in options. Because you must use CharToOem/OemToChar for text in description and for filenames.
At this moment I cannot see correctly Russian letters from standard description neither English letters in description for Russian filenames. So XnView shows only English description for files with English letters in name for me.
Here is example:
descript.ion
"причём.jpg" english description for russian filename
"яЁшў╕ь.jpg" english description for _same_ russian filename done by xnview (wrong!)
"6.jpg" русский язык - russian description
"4.jpg" Ёєёёъшщ ч√ъ - same russian description by xnview (mess)
And some other things - there shouldn't be '"' symbols around filenames without space(s) in it.
And Edit description in XnView has wrong tab-order - should be Ok first, then Cancel.
That you said
• I just proposed the option for the description files like you said :
… where the [×] box is on the dialogue itself… A similar dialogue exists in XnView, of course (but without the tick-box).… Could you add such trigger "Use oem in descript.ion files" in options?
val
Re: That you said
I asked about option in the Options dialog for full correct support. You proposed just part of that. It won't be full and correct support.Clo wrote:val
• I just proposed the option for the description files like you said :… where the [×] box is on the dialogue itself…… Could you add such trigger "Use oem in descript.ion files" in options?
I know. But it wouldn't help with viewing descriptions in browser and viewer.A similar dialogue exists in XnView, of course (but without the tick-box).
Re: random sequence
Could you send me a description with samples? And which software use this description correctly?val wrote: No, I have not. It came from Dos to Windows - using OEM codetable (for russian cp-866) instead of ANSI codetable (cp-1251) in console apps. So you should use CharToOem/OemToChar.
val
Re: random sequence
Sure, I could. But I don't understand, what exactly do you want for samples. BTW, in descript.ion text is in one byte codetable. So for seeing what I see you should install Cyrillic fonts and change default language for non-unicode font to Russian. Maybe it's easier just to add checkbox "use OEM codetable instead of ANSI in description files" and call CharToOem/OemToChar right before writing to file and right after reading from file respectively, in the case when checkbox is marked. I mean such conversion for everything - filenames and descriptions.xnview wrote:Could you send me a description with samples?val wrote: No, I have not. It came from Dos to Windows - using OEM codetable (for russian cp-866) instead of ANSI codetable (cp-1251) in console apps. So you should use CharToOem/OemToChar.
try for example far manager http://farmanager.com/download.php?l=en (ctrl-z - enter/edit description, ctrl-6 - one of the view descriptions mode)And which software use this description correctly?
Re: random sequence
I've tried CharToOem/OemToChar but now i have a problem with others software that use descript.ion like ACDsee 3 & TCval wrote:Sure, I could. But I don't understand,xnview wrote:Could you send me a description with samples?val wrote: No, I have not. It came from Dos to Windows - using OEM codetable (for russian cp-866) instead of ANSI codetable (cp-1251) in console apps. So you should use CharToOem/OemToChar.
val
Re: random sequence
But I didn't say that everybody must have such option turned on.xnview wrote:I've tried CharToOem/OemToChar but now i have a problem with others software that use descript.ion like ACDsee 3 & TCval wrote:Sure, I could. But I don't understand,xnview wrote: Could you send me a description with samples?
I don't use TC (for me Far is much better), but ACDSee 3 definitely has option "use OEM codepage" - I had widely used it before new versions become use own database. After that I found XNView.
But even ACDSee doesn't work correctly with CharToOem/OemToChar translations - it uses such translations only for descriptions missing filenames. So it forced to use only English letters in filenames.
And what's about original suggestion of random viewing with keys Space/Backspace, while PgUp/PgDown still let view in sort order? Have you turned it down?
