I just stumbled over the improved companion handling feature - to discover that it is probably no improvement for me:
I want to move companion files like .xmp (Photoshop creates them when converting) together with raw files, but I DON'T want to move jpgs. E.g. after converting a raw file I usually delete it, but of course I want to keep the jpg I just produced.
Is there a way not only to define what a companion is but also what is NOT a companion?
(By the way: Messing in an .ini file is not a very user friendly way to set preferences.)
regards
Joachim
defining companions
Re: defining companions
Yes, change Companion_ item in xnview.inijotess wrote:Hello,
Companion_ item?
is "Companion_ item" something different than e.g.
[File]
Companion_00=nef:xmp
Companion_01=xmp:nef
in the xnview.ini?
This defines what a companion IS. But how to define that .jpg is NOT a companion? Neither in the help nor in the forum I could find a hint on "companion_item"
regards
Joachim
[File]
in the xnview.ini?
regards
Joachim
Re: Companion_ item?
If you have only:jotess wrote:Hi,
[File]
in the xnview.ini?
when you delete/copy/move a .nef, the .xmp will be too
If you have:
Companion_01=nef:jpg
when you delete/copy/move a .nef, the .xmp & .jpg will be too
This would be clear. But I had NEITHER specified in my xnview.ini, I just had the checkbox in the preferences checked. ("For copy/move ... /.jpg)"). So jpg seems to be included by default?If you have only:
If you have:
Yes by default xnview usejotess wrote:This would be clear. But I had NEITHER specified in my xnview.ini, I just had the checkbox in the preferences checked. ("For copy/move ... /.jpg)"). So jpg seems to be included by default?If you have only:
If you have:
Companion_00=nef:jpg
So in your xnview.ini, add Companion_00=nef:xmp in Browser section
Aaaaah! I got it.
So just to understand better what I did:
- What is the difference between the entry in the browser section and
in the file section?
- Nothing specified means default = jpg is included with raw, thm, ... and
something specified means: everything not specified is not included?
I believe some text box in the options dialogue with a good explanation would be very helpful.
thanks
Joachim
thanks
Joachim
Sorry it's File sectionjotess wrote:Aaaaah! I got it.
Yes, currently i use default settings if you don't want to change companion file....- Nothing specified means default = jpg is included with raw, thm, ... and
