I wonder why the tabs have no x on the right side to close them directly with the mouse, like in TC and IE7. Would be nice to have.
I also wonder about the option 'Use default tab control' in Settings, Interface. What does this one do?
Mouse close of tabs
Re: Mouse close of tabs
Yes, already requestedpic_viewer wrote:Hello,
By default, it's my own control, by enabled it you use the standard control (to use theme).I also wonder about the option 'Use default tab control' in Settings, Interface. What does this one do?
pic_viewer
Ok, I now saw the minimal difference. May I suggest this wording to avoid further questions like mine:xnview wrote:pic_viewer wrote:By default, it's my own control, by enabled it you use the standard control (to use theme).I also wonder about the option 'Use default tab control' in Settings, Interface. What does this one do?
- Use XnView theme style for tabs
Or this one, but it would reverse the function:
- Tabs use current theme style
Wonder, wonder…
• I wonder that you don't know one can close the tab with a double L.M.B.…
pic_viewer
Re: Wonder, wonder…
True, I did not know. Nevertheless I hate double-clicks and try to avoid them as much as possibleClo wrote:pic_viewer
Dreamer
pic_viewer
