Program crashes when using slider bar to listen to MP3s
fbiancol
Post by fbiancol »
using: Xnview 1.92 en, Windows XP SP2
I use xnview to help me sort through MP3 files, but as I click around the files, and move the slider bar (to advance and/or go back in the MP3 file while listening to it), the program freezes, and task manager shows it consuming 99% of CPU resources. The entire PC is basically frozen unless you can kill the xnview.exe process or logout (thus killing the process).
It's happened to me 3 times in the last hour....thought I should mention it.
I deleted the xnview.ini as suggested....no change in behaviour.
Overall....love the program.....I wouldn't bother posting this here if I didn't :-)
thx
Fb
I can't reproduce it at will....but given
Re: Program crashes when using slider bar to listen to MP3s
fbiancol wrote:Hi,
thx
Fb
Which OS? Is it possible to have the mp3?
Read---
:arrow: Pierre
:) Good morning,
• Anyway, I tested under XP-Pro SP1 with *.wav, various sizes, I can't reproduce that bug.
- It seems it's related to an external cause (faulty shell extension, hardware or whatever…).
:mrgreen: KR
Dreamer
Post by Dreamer »
Can't confirm.
XnView 1.92, Windows XP SP2.
Dreamer
