Missing file "MSVCP71.DLL" in setup ;)
Post by Guest »
XnView on clean XP SP2 instal, need for work "MSVCP71.DLL"
It will be nice when setup and zipped portable contain this file
Regards and heep good work like now !!! :)
ckit
Post by ckit »
Just install dotNet 3.5 Framework and you'll get the DLL.
Re: Missing file "MSVCP71.DLL" in setup ;)
Anonymous wrote:XnView on clean XP SP2 instal, need for work "MSVCP71.DLL"
No xnview doesn't need this dll, it's the OpenEXR plugin
oops66
Post by oops66 »
ckit wrote:Just install dotNet 3.5 Framework and you'll get the DLL.
Yes, or just delete (remove) the OpenEXR plugin dll under :
C:\Program Files\XnView\PlugIns\IlmImf.dll
FYI :I had the same problem under winxp sp2.
