how to store license infos from registry to ini?
Aleksei
Post by Aleksei »
I bought a license in the past and wanted to know if I can store these infos from registry:
LicenseName=******
LicenseNumber=********
to the normal xnview.ini so i can do a REAL and COMPLETE silent use on an usb stick.
thanks in advance.
No, but…
:arrow: Aleksei
:) Hello !
• AFAIK, there are no such entries in the INI file to store such data…
- I've also a licence, and I checked my INI : Nope !
• However, since that is useful for you - and I assume for other registered users -
maybe Pierre could plan such entries, to add "by hand" when needed….
:mrgreen: Kind regards,
Re: how to store license infos from registry to ini?
Aleksei wrote:Hi,
LicenseName=******
thanks in advance.
No currently license is always store in registry
Aleksei
Post by Aleksei »
xnview wrote: No currently license is always store in registry
oh, what a bummer :(
Should be possible I think.
So I will use it unregistered in my commercial usb-like way ^^
ikutluay
Post by ikutluay »
i think it is not a problem ... i have license too. (pierre kindly offered me a license thanks again)
azsd
Post by azsd »
Hi, Aleksei
I suggest you use ceedo or same kind of software to store your toolset on usb stick. It can hook registry access and emulate an same working environment on diffrent computers, sometimes stable.
Aleksei
Post by Aleksei »
azsd wrote:Hi, Aleksei
When I see Ceedo I see U3...
But, Thanks for adding this tiny option to the newest version ;)
