Tga not rendering correctly.
PowerBallTabs
Post by PowerBallTabs »
I swiched from 1.90 to 1.92 and incurred in a strange bug. Tga are not rendered correctly. It seems that some layer of the image are not rendered (presuming tga supports layer... I don't know at all). Take note i've cleared all my xnview.ini as suggested in the readme :)
Here are the screenshot of what I see in 1.90 (correctly) and 1.92 (not rendered completly) and the original tga file of course.
http://rapidshare.com/files/86371157/Screens.zip.html
Thanks for this great software anyhow :)
Moderator & Librarian
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=57101#57101]black color issue for PNG[/url]) wrote:Recommended settings:
  • View »
    • » Use alpha channel » On
      » Show Mask » Off
  • Tools » Options... »
    • » General » Read/Write » PNG » Parameters » Compose image with transparency » Off
      » General » Read/Write » PNG » Parameters » Compose image with alpha (32bits) » Off
      » View » View » Background colour » R128/G128/B128
      » View » View » Use checkerboard pattern as background » On
      » View » Fullscreen » Background colour » R128/G128/B128
See also:
PowerBallTabs
Tnx CTRL-H have done the work. Easy.
