I´m looking for a software able to resize PNG´s with transparency using lanczos algorytm.
I´ve already tried several but none of them seems to be able to deal with transparency using lanczos.
Before i install Xnview, i would like to know if ís it possible to resize png´s with transparency using lanczos as the resize algorytm.
Thank you.
Question about resizing in XnView
- Forum Librarian
Thanks XnTriq, but that´s not exactly what i need to know.
I think i wasn´t clear enought. What i mean is:
I have an image with transparency in png format (24bit+8it alpha) and i want to resize it keeping the transparency intact (it stays in the same png format 24+8 bit) and using the lanczos algorytm for resize.
In other programs i have tried all loose the alpha channel after the resize procedure, and top images editors like photoshop or fireworks don´t have lanczos as an option for resize.
- Forum Librarian
XnView doesn't loose alpha channelAnonymous wrote:Thanks XnTriq, but that´s not exactly what i need to know.
Amazing! Thank you for your reply. This is the first software i found that is able to resize 32 bit png using diferent algoritms and keeping the alpha channelxnview wrote: XnView doesn't loose alpha channel
Great work! And XnView is free!!!????
Thank you!
