Wrong filelist background color
Danny
Post by Danny »
IIRC the unknown files in the filelist used to have a white background color. Now all folders and all unknown files have a gray background here, if i switch on "use color based on fileformat".
The browser -> filelist -> misc -> background color option only works for the background of the icons.
How come? I want my white back.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Re: Wrong filelist background color
Danny wrote:IIRC the unknown files in the filelist used to have a white background color. Now all unknown files have a gray background here, if i switch on "use color based on fileformat".
In thumbnail mode?
Danny
Post by Danny »
No, in every mode really. Folders and files. That particular setting is for the details view.
Danny wrote:No, in every mode really. Folders and files. That particular setting is for the details view.
Do you have changed the text back color inOption/Thumb/Labels?
Danny
Post by Danny »
Yes, but i can change the settings all i want, it's always the same gray background color. The text color does react though.
Do you have tried with a clean .ini?
Danny
Post by Danny »
xnview wrote:Do you have tried with a clean .ini?
Yes, it's the same.
Danny
Post by Danny »
So? What is it? Any news on this? My background is still gray all the time.
If this is not my fault, can someone move this into the bugs forum? Thanks.
Danny wrote:So? What is it? Any news on this? My background is still gray all the time.
Will be fixed in 1.92.2
Danny
Post by Danny »
xnview wrote:Will be fixed in 1.92.2
Excellent. Thanks.
Danny
Post by Danny »
Just checked out 1.93.
1. It's unexpected that the thumbnail label text background has an effect on the the ordinary filelist as well.
2. Browser -> filelist ->misc -> background color has no effect whatsoever.
I would expect to find the filelists text background color at the latter position.
Danny wrote:Just checked out 1.93.
Sorry could you show the problem on a screenshot?
Danny
Post by Danny »
Image Image
[quote="Danny"][/quote]
I have not fixed this bug :-) For beta 2
Danny
Post by Danny »
Fixed in beta 2.
