Auto Crop - how does it work?
Peter2
Post by Peter2 »
I have two questions, maybe regarding the same thing.
a) Auto-Crop:
I don't understand how it works. What is "Tolerance", what is "Background color"???
b) Croping of white space:
I will get a lot of TIF files (black / white; 400 DPI, CCITT G4 or LZW), made by CAD programs. The "papersize" will be very large (i.e. 80 x 350 cm), but the "inked area" (the real printed area) will be much smaller (A4 - A1). The rest of the picture will be an emtpy area (white space). How can I crop (trim) the TIF to the "inked area + x mm white space"? With auto-crop?
Best regards
Peter
Peter2
Post by Peter2 »
Nobody knows it?
Please give me a hint.
Thanks
Peter
Peter2 wrote:Nobody knows it?
"Auto crop" try to remove a border with same color (+/- tolerance)
Peter2
Post by Peter2 »
Thanks, but I am still confused:
Tolerance in pixel / inch / cm / color depth?
How it works with B/W-Tiff?
Peter
Tolerance is in RGB color
On B&W, tolerance is not used
Peter2
Post by Peter2 »
Thanks, now I could make a testfile.
Question:
I took a tiff, B/W, 400 dpi, CCITT G4, 89 x 350cm, 129 kB, and cropped it (background black).
The result is a tiff, B/W, 400 dpi, CCITT G4, 89 x 235cm (correct cropping) , but 444 kB.
Why?
Suggestion:
The cropping uses exactly the last pixel. It would be nice to add a "space-tolerance" (positive or negative value; absolute in pixel or cm or relative in %) that is added to the "last pixel". With "positive space" I can add a small white paperspace around the tiff, with "negative space I can crop i.e. a frame, draawn around the picture (I use plans which have a drawn border-line around the plan.)
Best regards
Peter
Peter2 wrote:Thanks, now I could make a testfile.
Question:
Why?
Plase check the compression in option/Write
Suggestion:
Ok
Peter2
Post by Peter2 »
xnview wrote:Plase check the compression in option/Write
I have
"Colour: LZW"
"Black/White: CCITT G4"
"Only one strip" is not marked. If I mark it, I get immediatly the error "Not enough memory."
Peter
I have
"Colour: LZW"
And which compression is used by the original?
Peter2
Post by Peter2 »
Can I send you an example?
Peter
Peter2 wrote:Can I send you an example?
Peter
Yes
Peter2
Post by Peter2 »
I sent it now by mail.
Peter
Peter2
Post by Peter2 »
Hello Pierre
did you get the file (per hotmail)?
Peter
Peter2 wrote:Hello Pierre
Peter
Yes, i'll reply asap
Peter2
Post by Peter2 »
It is clear now: due to more tags, written by Xnview (and not written by the other software), the file size increased.
Peter
(Thanks to Pierre.)
