Reset X/Y doesn't work when "Lock Zoom" is on
NM64
Post by NM64 »
Whenever viewing an image larger than your window, it defaults to centering it. Checking "Reset X/Y" will then make the viewer always go back to the top of the image when you move between images.
Problem is (at least in my case), whenever using "Lock Zoom", the fuction of "Reset X/Y" is disabled. It's still checked in the options (and even gets "reactivated" as soon as I disable "lock zoom"), it just isn't being used.
I've noticed issues with reset x/y right when I started using the program, and didn't know what was up. (I even made a topic and didn't want to admit the Reset X/Y wasn't working because I tried it already) I eventually figured it out a week or so ago the problem.
...now I'll look like a complete idiot if this is already known or just a problem I'm only having. (or even worse if there are separate options for "Locked Zoom" mode that I didn't know about. XD)
I'm using Windows 2000 Pro SP4 and XnView v1.92.1
Here's a video showing what I mean. (the quality is kinda crap, but it gets the point across. It's not like it's Crysis :P)
http://hostfile.org/XnViewBug.swf
