I tried to open a jpg file by hitting enter in the TC. Usually XnView starts in viewer mode and shows the file. This time XnView started the browser with the last used directory. I wasted about 15 minutes until I finally discovered that the file had been invalid - size 0 Byte.
Please add an error message dialog when trying to display files where this process fails.
Error message missing
Re: Error message missing
If you try to open it directly in xnview, do you have the error dialog?pic_viewer wrote:Hello,
pic_viewer
Strange, i have "Error when opening the file xxxx" if i use enter, double-clic or menu/openpic_viewer wrote:Start Viewer, Open, file: Error message 'Error when opening the file xxxx.jpg:
Start browser, navigate to 0 Byte file: no preview. F11 not work. Enter or doubeclick on this file just resets the browser mini-pic view. So no error message in browser no matter what you do.
pic_viewer
Pierre, I am sorry, but I am not able to send personal mails via this forum to you. Whatever I do I get the mail sent to myself. Part of the problem may be that it is all in french, but on the other hand it simply should work when I click on someones name and the option to send him a PM. It does not.
So if you want a sample file showing the error on two different machines then please send me a valid email adress where I can send it to.
